Stainless Steel fasteners
I’ve used many polished stainless screws on my bikes. Love the look of chrome without the rust and corrosion. Just make sure u use the correct hardness of bolt for the application. On brake bolts etc, I use chromed steel bolts with stainless washers ( the bolts are stronger but the stainless washers won’t rust when bolt is torqued onto them). I use Gardner Westcott fasteners and have been very happy with them. Good luck!
blacktop37 (04-07-2018)
Oh dear Lord.
I have swapped out more stock fasteners with polished and standard stainless fasteners than you can shake a stick at. I have never regretted it. I never use stainless on load bearing bolts, but for sure on everything else. I'll tell you another thing I like doing is swapping all my washers for brass washers. Just a little extra flash.
Oh dear Lord.
I have swapped out more stock fasteners with polished and standard stainless fasteners than you can shake a stick at. I have never regretted it. I never use stainless on load bearing bolts, but for sure on everything else. I'll tell you another thing I like doing is swapping all my washers for brass washers. Just a little extra flash. ��
FlyingSkeet (04-09-2018)
Received 14,669 Likes
A relatively easy way to do this is take your tools with you that will be needed. Head to your local Ace hardware, take one size out at a time and get what you need. I have done this and worked great for me.
But gee thanks for reminding me that I need to spend yet even more money on my new bike....
A while back I posted up some close up pics of my Springer Dyna Low Rider. It was a true brass *****. But it appears that post was a victim of the filthy scumbag we call photobucket. Cause none of the pics are viewable...
https://www.hdforums.com/forum/dyna-...red-parts.html
