Stainless Steel fasteners
Old 05-03-2018, 06:31 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
Alloyboltz.com has complete sets by model with the correct grades. They recommend assembly lube, loctite and modified torque values.
Old 05-03-2018, 06:59 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Originally Posted by GOV5
, how do you know you're getting Grade 8 replacement screws?
Bolts are marked with their hardness. Once you know the system, it's fairly easy to decipher.
https://m.youtube.com/results?q=how%...e%20bolts&sm=1
Old 05-03-2018, 07:04 AM
Torky_SOB's Avatar
Torky_SOB
Torky_SOB is offline
Received 9,762 Likes on 3,684 Posts
http://www.depss.com/index.php heres another very in depth vendor too. Grd#8 and polished from button head to 12 pt.I was beginning to do this and will finish now. I had some other mods I wanted done .Now I have the $ and the time ,They are also located in my state.He even has some 12 points with shaved down heads to fit on brake rotors for softails (nice to see them accommodate many different types of fasteners ) Just giving you & others some more options. I talk to the owner, nice guy,takes time to explain and give ideas or advice on some of his items.
Old 05-03-2018, 10:05 AM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,615 Likes on 2,870 Posts
Originally Posted by harleybob815
https://alloyboltz.com/
ty harley
Old 05-03-2018, 10:07 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,986 Likes on 4,177 Posts
Ride more....and smell the roses..beats sitting around the garage looking at Harley's fasteners..causing a leak or a pain someday when you do have to pull it apart...If you just have to..Cap it.
Old 05-03-2018, 10:41 AM
rocket23's Avatar
rocket23
rocket23 is offline
thats what my bike has now.......I only replaced the windscreen fairing bolts with stainless so far
Old 10-15-2019, 06:32 AM
bustert's Avatar
bustert
bustert is offline
as a steel guitar builder, i deal with aluminum extensively and use stainless fasteners. i replace the stock fasteners on my machines when they start looking bad. stainless will polish up like chrome. a big issue with the hd material is it is not aircraft quality and that poses an issue with corrosion but it doesn't take much to put the brakes on it. you can use anti-seize or silicon grease or even johnson paste wax which when it dries with engine heat acts like a mild thread locker.
Old 10-15-2019, 10:50 AM
mmclaughlin316@yahoo.com's Avatar
mmclaughlin316@yahoo.com is offline
Default Diamond Engineering
Do an internet search for Diamond Engineering in Holly Hill FL (Daytona suburb). Ignore their website, it's completely useless for anything but their contact info. Call or email and ask for both of their catalogs. You will NOT believe what they have for Harleys, and metric too!. I've replaced damn near every visible fastener on my '16 FLHR with polished stainless 12 point, cap head or button head as needed. Wait until you see their catalogs!
Old 10-15-2019, 12:02 PM
dickey's Avatar
dickey
dickey is offline
Received 5,651 Likes on 2,536 Posts
Just curious...I am a pedal steel player (check my avatar); was wondering what company or builder you work for?
Old 10-16-2019, 05:21 AM
bustert's Avatar
bustert
bustert is offline
http://www.pedalmastersteelguitar.com/
we shut down the company a few years back since my father has macular degeneration. we still do some work but not like it was. the guitar was sold all around the world. there were no two alike, everything custom made to owner's spec and could range from 1500 dollars to 10,000 dollars (24k gold gilded).
i am in the process of building a shop and moving the machine tools and probably quit after materials are gone.
bruce sg08
09-15-2012 11:17 AM
HEYENG
02-16-2008 04:57 PM
bladesmith
01-31-2008 11:09 PM
cpa55
Detailing
01-01-2008 12:49 PM
wrustywrench
04-05-2007 10:31 AM
Quick Reply: Stainless Steel fasteners
