Primary and Transmission Bearings Replacement Already???
Update
Thank you all again for your help.
Drew
- Replaced the tensioner with a new Hayden brand. The old tensioner was pretty bad.
- The noise is quieter, but it still rattles a bit in 1st with the clutch fully engaged and louder while in neutral. Noise persists in all gears. (somewhat quieter in taller gears)
- During Primary Oil removal, the plug was covered in silver/glittery oil.
Drew
Tear it down and look at it if the ipb is fine then leave it it's the same process for either one either way the inner primary has to come off. I am willing to bet the ipb race is all chewed up and that's where the silver glitter came from. If it is make sure you clean that silver stuff out of the main clutch bearing or it will eat that up too.
It is not that expensive. I had a shifter shaft seal leaking. I figured while I had to remove the inner primary, I might as well rebuild it.
You can buy everything you need from Baker. Look in your manual you will need some special tools to do this.
There are you tube vids for reference.....
If you are not comfortable doing this I would look for a good Indy in your area.
