Installing Harley Center Stand
I am interested in installing the Harley Center Stand on my 2017 Ultra Limited. It says this center stand will not work with bikes that has the 50768-07, which are the adjustable passenger footboard brackets. I have these adjustable passenger footboard brackets adjusted straight up so that they are as tall as they can be. I don't understand why the center stand isn't compatible.
Anybody know or have any experience with both?
Thanks
Thanks
I used one of these (below link), before I installed a True-Track stabilizer.
https://wheeldock.com/products/ez-up...nt=31591621710
I am normally a big support of HD parts. This is a time I would recommend trying one of the others people have listed. The HD one I purchased is hanging on the wall near the bad idea box. Read the HD information it is marketed as a display stand. Easy to install big pain to use and not every effective.
Second this post. EZ up is the way to go
I have the Harley center stand installed on my Street Glide. I expect Harley is covering all their bases on the install fit. It is possible the stand will come in contact with the footrests while the stand is in the up position. It is also possible that with the footboards you might not be able to actually get your foot on the stand while seated. It appears the stand will settle directly under the passenger footboard. I have a EZ-UP also and I believe the situation will be the same.
dasmotorrad (06-09-2020)
Received 49,744 Likes
The EZ-Up Stand install quickly ... It almost jumps out of the box, runs across the garage floor and installs itself ... Operating the stand is quick and simple and after a couple of tries you'll be proficient ... Don't use the stand if the scooter is facing "downhill" ... Using it really is as simple and easy as the video on their site shows.
