stronger starter motor?
Old 03-30-2018 | 10:20 AM
PPearl's Avatar
PPearl
Mine was doing that, they upgraded my compensator to a SE one and it's much better now.
  #32
Old 03-30-2018 | 10:51 AM
hattitude's Avatar
hattitude
Originally Posted by doug62
I have been told a stronger starter motor will stop the occasional (but often enough) issue I have when I try to start the bike and the engine kicks back against the starter motor and makes an awful racket. Has anyone else ever heard of this remedy?
Bottom line, as the bike is designed, you shouldn't need a stronger starter with your mods....
As many have suggested, there could be several issues causing your problem. You have a good list of things to check....battery, connections, tune, ACRs, starter clutch, compensator, etc, etc, etc......
While a new, stronger starter may temporarily solve your problem (unless the problem is a bad starter clutch, then you will have accidentally fixed the problem) it will just mask what the core issue is... eventually the issue will rise to the top and maybe leave you stranded.
Better to fix it, then mask it....
  #33
Old 03-30-2018 | 10:56 AM
TriGeezer's Avatar
TriGeezer
My ‘12 does it more frequently if a try to start it in gear, much less in neutral.
  #34
Old 03-30-2018 | 11:21 AM
ohioflhs's Avatar
ohioflhs
Like someone else said, hit the starter button just a second before starting to bring the piston off compression stroke which is where it stopped when you shut it off last time. Only addresses the symptom, not the actual problem.
  #35
Old 03-31-2018 | 11:26 AM
Sparkee...'s Avatar
Sparkee...
I checked my ignition tuning map the other day and applying -3 degrees to the top right 3 cells on the lowest rpm row is what cured the hard starts for me. It has no impact on performance since the ecm only uses these cells on startup.
  #36
Old 03-31-2018 | 12:31 PM
Mertoid's Avatar
Mertoid
I also start my '11 in neutral. Hit the start button as soon as I turn on the ignition, don't wait for the fuel pump to stop. I don't know why it helps, but it does. Also, 3 years seems to be the max for my Harley batteries. As soon as it consistently struggles at the hit, it's new battery time.
  #37
Old 03-31-2018 | 09:53 PM
2whlr4life's Avatar
2whlr4life
Arrow
Subscribed.
  #38
Old 03-31-2018 | 11:31 PM
1Canuck's Avatar
1Canuck
Ok, here's what I have. A 2013 Ultra Classic, aside from a Stage 1 it is bone stock. The battery is brand new and the cables are tight. I'm pretty sure it has compression releases, please correct me if I am wrong. And yes, I do wait for the fuel pump to prime. It seems to do it only when the bike is cold by the way.
1) stock battery and two starter clutch replacements
2) new battery all well for a while.
3) bought new starter, rated stronger, it lasted one month, but way stronger. they would not sell me another one (China made bad batch)installed old starter. back to hard starts.
4) bought another new battery even though all tests said one year old one passed. That was 3 years ago and no more hard starts. get a new battery
  #39
Old 04-01-2018 | 04:48 PM
lionsm13's Avatar
lionsm13
The Starter Clutch is a weak link.
  #40
Old 04-01-2018 | 09:36 PM
6 gun's Avatar
6 gun
I have 10.5:1 compression and no compression releases what so ever, but I also put the HD 1.4 KW starter on it, a long time ago, and I have never had any problem whatsoever with hot starts but with my OEM starter I had a lot of problems.
Quick Reply: stronger starter motor?
