How do you remove the stock shift linkage to add hyme joints
Old 07-13-2007 | 02:00 PM
RangeRat's Avatar
RangeRat
Default RE: How do you remove the stock shift linkage to add hyme joints
I've been seeing the same POS threads too and picked up the HD stainless round last weekend. If I get 2itthis weekend I'll take some measurments first and post some answers for y'all.
Steve
Old 07-13-2007 | 02:06 PM
gilbos440rt's Avatar
gilbos440rt
Thanks Steve
Old 07-13-2007 | 02:26 PM
Arvid's Avatar
Arvid
I just went to the local hardware store and for the rear its a 5/16 x 24 stainless, for the front I got an SAE threaded 5/16 and a nylon lock nut. FYI I didn't just change out the heim joints, I replaced the linkage with a thirty five dollar stainless linkage from Jireh Cycles.
Arvid
Old 07-13-2007 | 05:44 PM
gilbos440rt
Thanks Arvid, I just picked up some 5/16 x 24 bolts and lock nuts. 24 TPI front and back?
Old 07-13-2007 | 06:34 PM
swipter's Avatar
swipter
Did this a while ago. thanks all.
Old 07-13-2007 | 07:57 PM
Arvid's Avatar
Arvid
24 TPI will work for both front and back but you will only need a lock nut on the front. The shift lever on the tranny is tapped. Be sure you measure the distance on the original shift linkage so you can get the heim joints the same distance apart. Don't forget the blue thread lock(Loctite)
Arvid
Old 07-13-2007 | 10:04 PM
gilbos440rt
Got it on and looks good thanks for all the support, much easier than I thought
Old 07-13-2007 | 10:23 PM
RangeRat's Avatar
RangeRat
Good deal gilbos.[sm=smiley20.gif]
ponesma
07-15-2014 09:15 PM
dmpjr
03-04-2013 01:56 PM
Figstr
03-03-2012 10:27 PM
Kroozer
03-11-2009 05:38 PM
Inferno00
05-18-2006 02:39 PM
Quick Reply: How do you remove the stock shift linkage to add hyme joints
