Wanting to install 21 in wheel on ultra
I have a 2013 Ultra and looking into installing a 21 in custom wheel. I hate the stock turbine looking one. My bike is non ABS, so is the wheel I'm looking at. a couple of questions for those that know. After mounting the rotors will the wheel be the right width or do some require aftermarket spacers to match the hub? Will this wheel fit in the stock fender or do guys change that out too? Thw wheel I'm looking at is 21x3.5 if that helps.
I can't provide definitive answers as I'm in the process of upgrading myself, but I can tell you 21" w/120/70-21 tire should fit under fender okay, though it's highly recommended to tape a 1/4" nut to tire and spin to make certain there's at least that much clearance. If more clearance needed, my understanding is holes on fender can be drilled out slightly to provide slightly different mounting position. Total diameter is approx 2.5" more than stock combinations so lifts front end about 1.25" higher which changes steering geometry, adding trail and making low speed maneuvers slightly more difficult. Some lower front forks to compensate, while others seem to be happy as is. Difference re ABS is irrelevant; simply a different bearing installed in one side of wheel. Haven't heard of any issues or spacers necessary for rotors and didn't think to ask that question, so I hope to hell they line up...
Good luck. Oh and have $$$$$ available for that wheel.
The 21" wheels are popular with the King guys on here, and some have good luck with leaving the stock fender on. A buddy has a '12 King and he adjusted his stock fender a smidge (elongated the mounting holes). He can go back to a smaller wheel if he chooses, where a wrap fender looks good with one size.
My buddy runs Avon tires with a 120/70x21 up front. Overall diameter is 27.9", so compensate your forks accordingly with your current tire size.
Got no idea, I've just observed some comments on the forum about guys who've gone to a different size...most 21's...and reported problems. On one of my former Harley's, I went from an OE sixteen front to a twenty one narrow front, and the handling went to hell in a handbasket. I was trying to achieve a certain look, so I thought this was a reasonable tradeoff at the time, and I learned to deal with it. But it's not always possible to have your cake and eat it too, so to speak.
I hate to see a guy change to a 21", immediately get rid of his OE set up, and rue the day.
