Overlay fender with my tourpak
Got 02 ultra with tour pak and i picked up a Bad Dad overlay fender with embedded brake and tail lights. Been following on line as far as overlay fenders that it eliminates all the hardware that holds the tour pak being that it covers over the area. Is it possible to cut out areas needed to retain hardware for oem tour pak. Or what is all needed to keep tour pak and add overlay fender on rear??
I didn't cut the fender at all. I started by mounting the quick release rubber studs on the frame rail where they wouldn't interfere. Then out came the cardstock paper to make the rails and top plate. Transfer it to 1/8" plate, cut it all out, weld it all together, paint and done.
Took me about 25 or so hours to build, very time consuming to build anything from scratch. But my total cost was close to $0 because I already had everything I needed. I'll take some pics next time I pull the bags off
