Cruise control?
Old 03-12-2018, 09:30 PM
Blackjack1's Avatar
Blackjack1
Blackjack1 is offline
Default Cruise control?
So this may have been covered already, I did a quick search and didn't see a thread focused on after-market cruise control.
Looking for an older RK, many either don't have factory cruise or if they do/did, moco no longer provides replacement parts; so: what are you folks doing for cruise control on older (pre 2009 Road kings, street glides etc..)?
The thought of hours without switching hands is a non-starter...
Old 03-12-2018, 10:31 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
Back in 2014, All parts for cruise control were available from the motor co, except for the actual cruise unit that was manufactured by Delphi. This was discontinued in 2005 and NOS was used thru 2007.
About the only way to find this unit today is USED. Lots on ebay, have to take your chance of it working.
if you want cruise, it can happen, it just takes time, persistance, a parts book to get all the part numbers and a willingness to run down every piece.
I put cruise on my 2004 police road king when I converted it to a road glide. It took about 8 weeks to find and receive everything. I have a little over $400 in parts and about 5 hours of my time in running stuff down and around $200 in labor from the install as I had no instructions.
if you want it, it can happen. I would start with eBay, or any used harley bike parts seller.
Old 03-12-2018, 11:19 PM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Here is a site. It is confusing as hell, I would call them.
https://www.harleycruisecontrol.com/
Old 03-13-2018, 03:19 AM
Tarkus60's Avatar
Tarkus60
Tarkus60 is offline
I found a NOS module on Ebay for my 02. I bought some new extra cables also.
This is just in case....
Old 03-13-2018, 04:18 AM
nobodyknowsme's Avatar
nobodyknowsme
nobodyknowsme is offline
Received 14,670 Likes on 6,425 Posts
Always been a huge fan of CC but throttle lock is next best thing. I looked seriously at cruise for my Road King for a long time and were it EFI would be more reasonable, but carb threw a whole other financial wrench into the cost factor. I learned to live with the lock.
Look at Road King Classics as many of them do or did have cruise.
Old 03-14-2018, 01:50 PM
bkmarsha's Avatar
bkmarsha
bkmarsha is offline
6th Gear
As other have said here you have to track down the parts and become familiar with your manual.
I completed the job for my 2007 street glide with no issues
Old 03-14-2018, 02:22 PM
KCHD1's Avatar
KCHD1
KCHD1 is offline
I know this may sound like BS But years ago I had a 1976 Super Glide and it had a brass knurled screw on the underside of the throttle grip with a spring on it. It was designed so you could adjust throttle tension. I used to set it very firm and had no spring return to the throttle it was "set it and forget it" Maybe you can find an older throttle set up and use that it worked fine for me for years. Man things used to be a lot simpler back then.
Old 03-14-2018, 02:29 PM
67Shuv's Avatar
67Shuv
67Shuv is offline
Veteran: Marine Corp
This earlier 2000's touring bikes and probably others, had a thumb wheel (tensioner) on the bottom of the right side control box. It worked just fine. I know my dads 2005 Electra Glide had it.
Old 03-14-2018, 02:32 PM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Veteran: National GuardVeteran: Navy
Received 1,670 Likes on 1,088 Posts
Brass screw, now that's fancy and complicated!
From the cheap seat section ;-) :
Old 03-14-2018, 04:22 PM
ABQ-Jammer's Avatar
ABQ-Jammer
ABQ-Jammer is offline
Received 4,753 Likes on 2,317 Posts
I think you're talking about these (https://www.ebay.com/itm/NEW-REPLACE...hWTKGN&vxp=mtr), but I also added one of these (https://www.ebay.com/itm/MOTORCYCLE-...Bansnc&vxp=mtr) to make it easier to "engage/disengage" it with my thumb. Those, combined with one of these (https://www.ebay.com/itm/Universal-M....c100005.m1851) makes those long trips rather nice. Basically, anything that can hold the throttle in place, but still allow you to turn it in an emergency situation, will do, but I like that little aluminum arm with the start bolt under the switch housing/cover, as it looks good, almost like it came from the factory, and it works great.
Quick Reply: Cruise control?
