Looking for a little advice on SG handling
Old 03-12-2018 | 11:54 AM
bigskyroadglide's Avatar
bigskyroadglide
Originally Posted by swing2hard
This is my set up front & rear.
21" front 16" rear Sinister Big Daddy wire wheels & yes using the stock Street Glide Special rear shocks.
I think the rear needs to come down an inch, or the front needs to come up an inch.
I would suggest better shorter rear shocks.
I would also check spokes and tire pressures.
sounds like extra weight is causing, some of the issue but poor handling is from reducing trail.by the front end lowering.
swing2hard (03-12-2018)
Old 03-12-2018 | 12:02 PM
swing2hard's Avatar
swing2hard
The specs on the JL audio amp says it weight 6 lbs, is that enough to throw everything off & make it want to dive into a turn?
Think I might yank it & see how it responds.
Old 03-12-2018 | 12:07 PM
swing2hard's Avatar
swing2hard
Here is what the amp looks like.
Old 03-12-2018 | 12:32 PM
Stopit's Avatar
Stopit
That is pretty centered in the fairing , the bike is engineered to add Boom audio amps in that same spot. Looking at your 1st pic it's pretty noticeable how much higher the front of the frame is compared to the rear , I'm no expert by any means but having the front that much higher than the rear would make the front top heavy by leverage in my mind.
Old 03-12-2018 | 02:49 PM
shore's Avatar
shore
Just to put this out there, have you checked the front tire psi. I had a fat bob that would dive into corners. Weirdest thing ever. I was checking the fall away and the fork fluid...then checked the tire psi. It was way down. Straight line showed no issues. Slow turn and it the bars fell in hard. Just an idea.
The following 2 users liked this post by shore:
CoolBreeze3646 (03-12-2018), swing2hard (03-12-2018)
Old 03-12-2018 | 02:55 PM
Outkast6991's Avatar
Outkast6991
There is no way the audio weight is causing the issues you describe. I'd be looking hard at the forks if it was me
Old 03-12-2018 | 03:00 PM
bigskyroadglide
On any batwing fairing the addtl weight on the front fork is around 20lbs vs a frame mounted set like a road glide. So 6lbs is about a third. Yes, it could make a difference, however I still think you have other issues.
think about how you have changed your bikes geometry and the line between the front wheel and rear wheel.
that's where your problem lies in my opinion. The weight just of the amp, enhances the problem.
Old 03-12-2018 | 03:23 PM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
26* rake at the steering head (29.25* fork angle) and 6.8" trail is stock on '15 SGS/RGS per HD. The rest of the touring line is 6.7" trail. Slightly less trail is better steering at slower speeds.
Old 03-12-2018 | 06:59 PM
bigskyroadglide
what he said, he said it a lot better than me
swing2hard (03-13-2018)
Old 03-12-2018 | 07:29 PM
CoolBreeze3646's Avatar
CoolBreeze3646
The tires look a little soft in the picture. Try airing them up to the max listed on the tire and try that. I have had issues on other make bikes when the tires do not have the correct amount of air in them and they want fall (dive) into the corners. Airing them up costs nothing, give it a try.
Quick Reply: Looking for a little advice on SG handling
