RK Rear Brake Pedal Height Adjustment?
06-20-2007, 10:58 AM
Is there a way to adjust the height of the pedal? Looked in manual and at attachment points and could not see a way to adjust. It is too high off the floorboard for me.
Thanks
Smitty
06-20-2007, 11:16 AM
RE: RK Rear Brake Pedal Height Adjustment?
Look into *
EZ-Brake *. It's designed with a reduced angle on the pedal. Runs bout $169 bucks but it replaces the whole arm.. There is no way to adjust the stock pedal that I'm aware of...
http://bellsouthpwp.net/e/z/ezbrake/index.htm
06-20-2007, 12:12 PM
Put my EZ Brake and EZ Shift on two weeks ago what a great easy cheap mod
Highly Recomended!
06-20-2007, 06:16 PM
Also take a look at
www.softbrake.com similar product, runs less $$$-- about $135.00
06-20-2007, 06:18 PM
Put over 1,000mi on my softbrake set-up in last 2wks,and it works great...
05-09-2013, 07:32 AM
has any one found a spacer you can add to the rod from the master. to make the pedal higher?
05-09-2013, 08:38 AM
Quote:
Originally Posted by
Nunner
I don't know anything about it, but Softbrake has an adjustable rod for $29.95 on their web page. Part number SB-BAR.
Micromark
06-28-2019 11:56 AM
Daddy454
2014-2023 Touring Models
21
04-25-2017 07:20 PM
Sliver1
01-11-2014 10:38 PM
WILLETTS
02-05-2009 06:27 PM
tramp
08-17-2008 01:41 AM
06 ,
2005 ,
adjust ,
adjustment ,
adjustments ,
brake ,
fltri ,
glide ,
harley ,
height ,
king ,
motorcycle ,
pedal ,
rear ,
road ,
street
