Hard shifting
Old 03-06-2018 | 06:17 PM
Veekness's Avatar
Veekness
Originally Posted by carlgrover
I've got a 98 road king with 90k on it that shifts like butter. As I was reading the responses in this thread, I was going to suggest you check your primary chain tension. I don't know anything about automatic tensioners but It sounds like yours could be too tight. I would also pull the clutch plates and fibers for a service. Clean, inspect, replace, and adjust. Lastly, I put 1 qt of Amsoil primary fluid in the primary. Your bike should take exactly the same amount. You don't have to go with Amsoil, that's just what I use. If this maintenance doesn't work, you might brace yourself for some transmission issues.
Keep us posted.
carl
Also good advice. Can act the same as a sticky clutch. OP, it occurred to me after you described how you had to free up your clutch that it still may not releasing all the way. If so, I'm not too certain that there's any better way to fix that other than replacing the plates. It' a pretty easy and quick job.
Old 03-06-2018 | 07:20 PM
OlAndrew's Avatar
OlAndrew
After I did that plates stuck together to the point of selecting a gear would cause the bike to go or die. I finally just revved the bike and dropped it in gear.
That's just about the definitive symptom of a clutch plate problem.
Old 08-26-2018 | 12:36 AM
wildhorse629's Avatar
wildhorse629
Finally tore down the clutch pack and discovered the issue. Some of the brass rivets on the spring plate in the kittle of the clutch pack popped out. The springs expanded and the rivets dragged so no matter how much I adjusted it just wasnt going to work right. Replaced it with and extra plate clutch pack and it now shifts great and grabs like it should. Thanks for all the advice.
goldeneyechance
04-21-2017 11:15 AM
07streetbobhd
04-06-2016 06:09 PM
doctoraustin
08-13-2013 10:56 AM
Pakrat
Shovelhead
09-30-2007 11:42 AM
g_amey
10-15-2005 11:57 AM
Quick Reply: Hard shifting
