Heat control mount on ultra ?
Old 03-04-2018 | 02:11 PM
DAVENRINO's Avatar
DAVENRINO
I got this one and velcroed the bluetooth controller to my clutch reservoir.
https://www.comforthouse.com/wireles...ontroller.html
Replaced my original clunker with all kinds of wires and boxes hanging from my liner and now have only the power wire from the liner. Works great and remembers the setting when I unplug. Pairs instantly and battery supposed to last 10 years.
Old 03-04-2018 | 04:13 PM
SnoRider's Avatar
SnoRider
That is the one I used to have. If you haven’t take some clear nail polish to that bad boy because it’s not waterproof. It fits great right under your right leg
Old 03-04-2018 | 04:45 PM
DAVENRINO's Avatar
DAVENRINO
Thanks, I wondered about that. I just installed it before I rode from Phoenix to Portland last July when it was hotter than hell and haven't gotten caught in the rain since then. Good thing I can replace the remote box for $25 if it gets damaged. I will try the nail polish unless I can think of a better option.
Old 03-04-2018 | 05:54 PM
SnoRider's Avatar
SnoRider
I weatherproofed it with plasti dip but ended up peeling it off to replace the battery. Then put those chrome **** in it and secured it with a magnet under the seat
Old 03-04-2018 | 07:30 PM
DAVENRINO's Avatar
DAVENRINO
Did you use a spray or an actual liquid dip? That sounds like it would work. I wonder if I could also put little o-rings on the shafts under the *****?
Old 03-04-2018 | 08:09 PM
CoolBreeze3646's Avatar
CoolBreeze3646
I used a RAM mount for mine so I can transfer it between bikes. Not the prettiest location but functional.
DAVENRINO (03-04-2018)
Old 03-04-2018 | 08:59 PM
SnoRider's Avatar
SnoRider
sprayed 5 coats. Dipping it would work better but spray was fine. I can’t remembe what I did for h2o at the *****
Missouri Snowman
08-10-2018 08:50 PM
Ultra_RB
08-01-2018 08:40 AM
1957buick
07-21-2018 07:51 AM
bunkertoby
03-05-2014 07:27 AM
jasonyankees
08-02-2010 10:18 AM
Quick Reply: Heat control mount on ultra ?
