Helmet Buffeting
Helmet Buffeting
I have a 2012 FLHTK and am having problems with buffeting that I believe is coming from over the top of the standard windshield. I am a tall person, about 6' 2" and sit fairly tall thanks to the rider backrest. Here is what I have tried so far:
1. The stock 12" shield and I get some buffeting.
2. A LRS 11" recurve and get some buffeting and look right through the top edge of the shield. It is tinted and I find that I prefer the clear shield.
3. A LRS 10" recurve and I look over it Like I am suppose to and the buffeting is the worst of all of these shields so far.
LRS gave me a good discount on a 14" recurve that I am going to try to see if looking through their shield helps the buffeting.
I additionally have a 13 inch non curved shield from EBay on order to see how that works. Cheap but may be effective.
I wear a 3/4 helmet all the time I ride as years ago I went down fairly hard and the helmet saved my head from serious injury. I do not ride without a skid lid.
Anyone else my size height wise have good luck with a shield that stops the buffeting on a batwing fairing? I had a 15 inch Harley tall shield years ago on the 09 Ultra I had at that time and it was pretty good, however I prefer not to look through a shield, but I may have no choice but to go back to the 15 inch shield.
Has anyone tried a small shield, like 3 or 4 inch and does that put you in a steady wind or is that not good either for someone my height?
And I see they make deflectors now for the glides with lower fairings too, however I think the most turbulent air is coming over the top of the shields I have, not from below.
Thanks a lot in advance for your replies and suggestions!
Phil
Phil
Received 14,670 Likes
I honestly don't know what to tell you. I have run a bunch of LRS shields on my bikes and never a buffeting issue. The closest I can come to your setup is my Road King. I have an LRS stock shield replacement and works great. But I also have a Memphis Shades fairing with an LRS shield. I look well over both and zero buffeting. Does your 3/4 helmet maybe have a visor that is catching air? Sorry, that's all I can think of but maybe after a bit more coffee...
Phil, the 12 inch shield on my 2015 Ultra works for me. I had to change from the 10 inch stock shield. I don't know what year HD changed from the 12" stock to the 10". The new one was also about an inch wider on both sides, and I think that is what reduced the helmet buffeting for me.
Could you see if the HDshop has one you could test ride?
Run a lot of different bikes over the years, with lots of different windshields/fairings. Pretty much any time I'm looking over it, my head is getting rattled.
Some has to do with my helmets. I like a visor on it, which tends to catch air. I also run open faced (no face shield), which also catches the air.
In many states if your fairing/windshield is tall enough, you don't need to have a faceshield on your helmet or wear glasses. Most of the time, this is my preference.
The fork fangs worked for me, I have them on two FLHTK's. They say they will not work with lowers but with some slight bending they work just fine.
https://www.harley-davidson.com/stor...20-57400146--1
I am chasing the same problem. 3 diferent height windshields and still have buffeting. It was suggested by Red ,that I try the fork deflectors. That will be the next thing I try. I have also noticed that my full face helmet does not get buffeted around. However my 3/4 does . I may try a different 3/4 helment.
I got buffeting wearing a full-faced helmet no matter which shield I tried. So, rather than spend more money on shields, I installed these, which have eliminated 80% of buffeting on my '14 Limited.
http://www.dkcustomproducts.com/cool...dk-cdw-trg.htm
