Notices
Proper Way to check critical fastner torque?
Old 06-19-2007, 11:16 PM
twilliams's Avatar
twilliams
twilliams is offline
Default Proper Way to check critical fastner torque?
Thinking of doing my 1k service myself, what I don't really understand is the proper way to check the torque of the critical fasnters list. I have the proper torque wrenches and know how to use them but do I first loosen the bolts then torque or set the torque wrench and just try and tighten the bolts?
Old 06-19-2007, 11:53 PM
Bryan1724's Avatar
Bryan1724
Bryan1724 is offline
Default RE: Proper Way to check critical fastner torque?
Just go over the bolts with the torque wrench set at the proper torque for said bolts/nuts.
Old 06-19-2007, 11:54 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
I would like to know too.
Old 06-20-2007, 12:15 AM
Rodent's Avatar
Rodent
Rodent is offline
Do not loosen them.
You are checking to see if any of them came loose.
Just set the torque wrench for a certain bolt and retorque it.
Old 06-20-2007, 12:23 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: tpmurray
But I already told you.
Old 06-20-2007, 12:36 AM
choochoo's Avatar
choochoo
choochoo is offline
To do the job properly you all better go back and read the book.
To properly ensure a fastener is correctly torqued several things must be correct.
clean and dry and freeof nicks, burrs, rust oil etc.
(unless the torque value specifically specifieslightly lubricated)
(this is NOT all inclusive but general)
The item being torqued (nut or bolt) must be still moving as the specified torque is reached and attained(if you continue to apply torque after this point you are now working against the friction of two surfaces that have mated resulting in an error reading. Plus over a period of time these "set" with heat/ cool cycles, corrosion etc so any further checking will result in an erroneous reading.)
Many new torque specs also include a stretch amount and a degree of turn after the initial
torque.
So you definitely need to read the manual on these specfic items to see what the specified torque amount is, and how is it applied.
If you are not familiar with the above procedures thenyou do not know how to use the tools properly.
So yes to do it properly you need to loosen and retorque per the instructions in the appropriate service manual.
Old 06-20-2007, 12:45 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: choochoo
Sooooooo what your saying is to remove the nuts and bolts, clean them, deburr, wire wheel em................................... and put em back in and torque em down? [sm=insomnia.gif]
Old 06-20-2007, 01:34 AM
choochoo's Avatar
choochoo
choochoo is offline
Noooooo!
You can pretty much presume the nicks and burrs are now gone after a factory assembly.
But to do a torque RIGHT the torque must be done in accordance with the specification (service) manual for that bolt.
If it says torque it dry then do it dry, if it says lightly lubricated then that way.
And if it say to a degree past the base torque etc etc etc.
But as we all should know and some don't.
Torque for example a primary cover bolt and then try to remove it a couple years later.
seems to have gotten tighter doesn't it (how many have stripped out the headwith the bit or screwdriver)? that is the "set" from hot / cold cycles and some corrosion that may have gotten in.
If you just apply a torque wrench to it set at the proper spec, the reading will be errroneous.
sure the bolt may be tight but the reading won't be correct.
The guy asked for the RIGHT way.
Right way to be correct is to loosen and re torque. And if dirt and rust etc, is apparent then the parts should be cleaned.
Are we all going to do it??? Of course not. But it is the right way, to ensure accuracy.
ORIGINAL: Bryan1724
ORIGINAL: choochoo
Old 06-20-2007, 01:40 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: choochoo
ORIGINAL: Bryan1724
ORIGINAL: choochoo
But if the bolt or nut has had Loctite applied to it and if you were to loosen it and re torqueor just go over said fastener with Loctite then you run the risk of breaking the Loctite seal. See there's where I have a problem with going over Loctited nuts and bolts. Once the Loctite death grip is broken it's just a nut or bolt that can work it's way loose. [:'(]
Old 06-20-2007, 01:44 AM
streeter's Avatar
streeter
streeter is offline
twilliams, get the service manual and a good torque wrench and go at it. Don't get caught up in this "loosen to check"[:@]stuff, it is not required on these critical fasteners norare there any torque to yield fasteners in the critical torque chart.You"ll have to lift the tank to get at the top stabilizer/engine mount. Put a wrench on the Jam nuts and you"ll be fine. Good luck!
Streeter
07 FLHXI
Quick Reply: Proper Way to check critical fastner torque?
