Street glide missfire
02-28-2018 | 03:45 PM
Stage III
I have a 2007 Street glide it’s ruff idleing and has a miss fire it will bog down and stall while idleing any recommendations
02-28-2018 | 03:46 PM
check for hole in fuel line inside tank
02-28-2018 | 03:49 PM
02-28-2018 | 03:55 PM
Stage III
It does have a intake leak would that be causing all the problems
02-28-2018 | 04:05 PM
Quote:
Originally Posted by
streetglide850
Yup. That would cause it to run as described.
02-28-2018 | 05:16 PM
Stage III
02-28-2018 | 05:28 PM
todd-67
And if run too long like that, you will have piston complaining about it and possibly an exhaust valve too.
02-28-2018 | 07:09 PM
If there is an IAC on your throttle body clean it with some MAP sensor cleaner, cycle the ignition off/on a few times. This gets gunked up from the oil vapors going into the body past the IAC orifice.
02-28-2018 | 07:14 PM
'14 Limited
Well there is that as well. I was not trying to be too real about it...... lol
03-01-2018 | 04:53 AM
Time for a new bike.
