Switching from CFR's to 2-1
Old 03-07-2018, 05:49 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
Originally Posted by hbsoldier3
You might want to consider a dyno, rather than a canned map.
Agreed. You can do a canned map yourself for free.
I'd call Dynojet and tell them what you're running and let them build you a map if you're gonna go that route. That's all that shop is gonna do and then charge you for doing it.
  #42
Old 03-07-2018, 07:04 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Keep us in the loop. I would like to hear the dyno results.
  #43
Old 03-08-2018, 06:34 AM
sabunimwil@gmail.com's Avatar
sabunimwil@gmail.com is offline
The shop is calling power Commander to get a map suitable for my setup. The nearest dyno is an hour ride away and is backed up 4 weeks. I have an appointment with Quick Performance set for 4 weeks from now for a dyno tune but for now I'm going to use what's available.
  #44
Old 03-21-2018, 02:34 PM
Got into the dyno early.
09 Ultra classic
Thunder Header 2-1 exhaust
TTS 150 cams
Stage 2 intake
Power Vision tuner
​​​​​​Dyno tuned by Quick Performance Cycles in San Antonio, Texas 89.44 hp
94.03 ft/lbs
hbsoldier3 (03-21-2018)
chaselee
03-05-2018 04:04 PM
Darkrider1695
11-02-2013 11:30 PM
stratplexi
02-16-2013 05:58 AM
jasonryen
12-02-2012 04:46 PM
Xone
VRSC Models
07-04-2012 05:53 AM
Quick Reply: Switching from CFR's to 2-1
