Have you ridden a bike with Progressive FST AND a bike with Ohlins 25mil carts?
When considering a suspension upgrade it is well worth considering whether you ride mostly or entirely solo, or like to take a favourite passenger. The choices for solo riding are quite good, as most of us will find a decent improvement with many of the brands of suspension upgrades that get mentioned around HDF.
However when we add a passenger, especially if you do long rides together, then the rules change! The riding experience for a passenger is quite different back there and some of the frequently mentioned suspension options are not up to the job. That is when deeper pockets are a godsend, as many loving passengers will agree!
Their post is useless, they don't sell Ohlins so make claims that are not legitimate. Buyers should always beware when a vendor gives you comparisons as their job is to sell you. I used Ohlins #3-#3 shocks, Ohlins # 6, Progressive 940, JRi, and Ricor. I've ridden bikes set up for me with Bitubo and Pro Action. Ohlin's #6's are the best hands down followed by Ohlin's #3-#3. In the front I used Ohlins 30mm fully adjustable cartridges, Progressive monotubes and Ricor. All are an improvement over stock but Ohlins is the clear winner. This is from a guy who has spent his own money testing the ones I mentioned and do not sell or am affiliated with any of them. I've also ridden bikes with the 25mm Ohlins and 20mm Traxxion AK-20, Ohlins wins here too.
Awesome to hear! Thanks for the info! Do you feel the Ohlins 30mm are worth more than double the cost of the 25mm? Subjective I'm sure, but having ridden them both, was it a no brainer or more of a diminished return when compared to the 25mm?
The #6 shocks are fully adjustable, as are Howards 30mm cartridges, so they represent the best there probably is. Ride quality will reflect the difference in quality of the design and hence cost. I very much doubt if there is anything subjective and that the difference between the two set-ups will be obvious with a very short ride.
Depends what you are running on the rear. If I was using the Ohlins #3 on the rear I'd run the 25mm and have a great combination. When I went with the #6 shocks I decided to run the 30mm. My are set up different than most. I had them built longer than stock for added stroke , then I raised them in my triple tree so the bike sits at stock height, then I cut holes in my nacelle so they come out the top and I can adjust them without removing anything. See the attached picture.
The following 3 users liked this post by tj316:
I have Ohlins front and rear, but shallow pockets, relatively speaking! I have #3-3 shocks and FKC101 cartridges, both supplied by Howard, of Ohlins fame. My shocks have limited adjustability and the cartridges have none, so they are the 'budget' version from the Ohlins range!
Have you had a chance to review the FKC101? Very interested to hear how they perform.
cartridges 25mm fully adjustable
I now offer a 25mm fully adjustable cartridge system that is also drop in (sort of as all are) that do not require fork tube modification. Good: easy to do and 2nd best cartridge system for Harley's. Fits all 49mm forks and easy to adjust from the top fork cap just like tj316. Bad: when you do not remove the check valve you can not pick your stroke of where it starts or stops or how long you want it. Maybe a little longer than the OEM 4.6 stroke but can be made to stop any place and can reduce the stroke to make the shock/cartridge shorter. Highest quality and made in the USA. It will not ride or control your bike as well as a NIX 30mm however. tj316's front end disappears. Stop on by and see the truth and not dazzled with BS.
