harley FLT tour glide shovel head blown gasget on push rods cove
Old 02-15-2018 | 04:06 PM
manuelviramontes68@yahoo.com's Avatar
Stage IV
Default harley FLT tour glide shovel head blown gasget on push rods cove
can I replace the gasket without removing the engine from the frame?
Old 02-16-2018 | 04:48 AM
grbrown's Avatar
grbrown
Yes. Get yourself the correct FSM, so you can see what is involved, including info such as torque numbers etc.
Old 02-16-2018 | 09:32 AM
Stage IV
Unhappy FSM what is it
thanks for your answer but can you explain what is FSM?
Old 02-16-2018 | 09:37 AM
Modo's Avatar
Modo
Factory Service Manual. Not a Clymer or Haynes.
grbrown (02-16-2018)
Old 02-16-2018 | 09:44 AM
grbrown's Avatar
grbrown
Thumbs up
Quite right! Your local dealer can supply, although may not have one in stock, otherwise there are on-line discount Harley dealers. Be wary of secondhand ones on Ebay, as they sometimes cost more than a brand new one!
Old 02-16-2018 | 10:18 AM
tc66nova's Avatar
tc66nova
Not sure what gasket you are talking about but if it is the push rod tube leaking you just need to change the o-rings where the tubes seat. If you are talking about the rocker boxes, you can remove the heads with out removing the engine and then take the rocker box off of the head and change the gasket. You will have to remove the head bolts and then spin the head on the cylinder about 90 degrees and you can roll the head and rocker box assembly off between the frame and the cylinder.
FF-BT
Touring Parts
07-29-2019 04:23 PM
VZ3
04-08-2013 09:56 PM
81 tour glide
Shovelhead
02-13-2013 07:37 PM
ro9beam2002
EVO
06-25-2012 07:56 PM
Tee&Vee
02-17-2012 05:55 PM
Quick Reply: harley FLT tour glide shovel head blown gasget on push rods cove
