Ok because of weak (old and damaged hands) i want to change me levers but not kill the bank. Does anyone know if the Kuryakyn Boss blades and the Trigger blades both have a shorter reach?
Just the reach or clutch pull? There are also items to make a lighter clutch pull as well if that is an issue. Albeit more than Boss Blades, you can get some pretty decent adjustable levers as well.
u can get reduced effort clutch which replaces the ramp and bearing in the clutch housing mine made a huge difference. I would also look at the adjustable clutch levers to bring it closer to the bars.
