Road King turn signals, front and rear, LED question
Pretty sure I have cd rear LEDs. I feel like they came with the lens as one solid unit that you put into the housing. Had clear lenses.
I went with clear lenses all the way around and just got cheap Ebay LEDs for the front. it think it looks great with the chrome and really lightens things up in the front. These pictures are bad but this is what I do. I couldn’t get over having a license plate cover up the pretty paint on my rear fender so I just relocated it
I can only parrot what’s already been stated about the custom dynamics. I was kicking around replacing the fronts for the extra light for nigh riding. Hesitant until I saw a set on a bike, during the daytime, mind you. Ordered some that day. Put them in a few days ago. Truely a “plug n play” installation. You can choose either smoked or clear lenses. I went w/clear for the extra lighting. The lenses are made differently then the originals since they actually hold the led lights in place. The lenses are a little expensive but we are all familiar w/HD and spending money for modifications. Only one thing is the signal indicator on the dash will flash about 2-3 times faster than when they had the OEM lights. The actual flashing speed at the signal housings are at the true speed just when showing on the dash display.
That was easy...
I called the HD Dealership about the possibility of needing to get a load equalizer. I was told, my bike already has one and that he failed to inform me when I purchased the lights. It was a very busy day at the shop that particular day and he forgot to tell me. All I had to do was turn the ignition switch to "acc." and activate my Hazard lights. After 10-15 second, the lights and dash lights were all flashing as they should be. Now I like fixes like that. Thanks Miklin, or I may have not even asked him about this. Appreciate the input. You had the correct answer and fortunately, the bike already had the correct part. I just needed to activate it so it could sync up. Thanks again Bubba.
striper.seeker
2014-2023 Touring Models
13
06-17-2016 05:03 PM
