clutch cable and brake line length
Getting ready to pull the trigger on ordering my clutch cable and brake lines for bar swap. I have the measuring but for those that have done it before I have a question regarding length.
How big of an issue is 2 inches too long?
Meaning if I measure and it looks like ordering +4 will work and I order +6 to be certain am I going to have significant routing or rubbing issues down the road?
I am planning to route in stock pattern. Bars are 12" twin peaks but for clutch it looks like going +6 over stock will be better as a 4" measurement appears as tho it will be too tight and cause a significant bend at the bar.
And rerouting for stock is not an option. I have heard this before but I am putting on custom cables so they are getting swapped no matter what.
Thanks in advance.
Thanks in advance.
INJEKTER (01-12-2018)
Yeah that is the process I have been working through. Measured last night but I am just thinking about what actual measurement to order. Do you get just enough, or should you leave a little slack?
The source for mine come in 2 inch increments over stock. So I am wondering if I go one size larger is being 2 inches extra going to cause grief or issues?
Yeah I was wondering because sometimes too short will pinch and rub through and sometimes too long can allow it to move where it shouldn't and do the same thing.
I pulled the trigger and ordered last night. Went with 2 longer than what I think will fit so that I have a little more wiggle room.
Northbound Southerner
10-08-2013 03:08 PM
