2012 Road King handle bar
Old 01-08-2018, 07:14 PM
HOG LEG's Avatar
HOG LEG
HOG LEG is offline
Default 2012 Road King handle bar
I ride a 2012 Road King with stock handle bars they make me reach and are uncomfortable on the long rides I would like to change but don’t know what to look for I don’t want to have to change cables if I don’t have to can anyone help
thanks
Old 01-08-2018, 07:46 PM
flanigans45's Avatar
flanigans45
flanigans45 is offline
Well your handle bars part # is 56902-08 . They have a 12in Rise With a 5in pull back. 11.25in base width. Generally speaking you can go up 2in. without changing cables. But if you pull the bars back like I did they will need to be longer. I put 14in mini apes.
Old 01-08-2018, 07:49 PM
HOG LEG's Avatar
HOG LEG
HOG LEG is offline
Thanks
Old 01-08-2018, 08:19 PM
HOG LEG's Avatar
HOG LEG
HOG LEG is offline
Are you saying that the stock bars are the 56902-08 or are you saying to try the 56902-08
Old 01-08-2018, 09:08 PM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
I have a Tallboy seat which moves me back 2 inches (long legs). So I needed more pullback. The Heritage-style bars did it for me. 57,000 miles later, I still like them.
Old 01-08-2018, 09:14 PM
HOG LEG's Avatar
HOG LEG
HOG LEG is offline
Ok thanks for the help
Old 01-08-2018, 09:24 PM
6113_'s Avatar
6113_
6113_ is offline
Received 33,004 Likes on 12,902 Posts
I'm ordering some Factory 47 Malos in the near future for the Road King, same height I think as stock bars but the pullback is more towards me and a little wider. I demo'd them at their shop and think they'll work just fine for a guy that used to be 5'9" but is closer to 5'8" thanks to time and gravity with a 30" inseam if that helps
Old 01-08-2018, 09:59 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,609 Likes on 2,727 Posts
thanks
Don't cheap out. Buy the most comfortable bars and the required cables and wires. You might be able to get away with stock cables, etc, but then you'd still be stuck with those hideous garden hoses, and they'd be all stretched and weird.
Old 01-08-2018, 10:22 PM
ajnigli's Avatar
ajnigli
ajnigli is offline
a lot of people swap out the start bars with heritage handle bars.
Old 01-08-2018, 10:37 PM
Dynamick's Avatar
Dynamick
Dynamick is offline
Not a Moderator!
Received 7,225 Likes on 3,431 Posts
Must be a mistake with that rise spec.
I switched to Wild Ones bars with 10" rise and they are substantially taller than the stock bars.
Quick Reply: 2012 Road King handle bar
