Compression releases
Old 12-15-2017 | 01:36 PM
2014sportsteriron883's Avatar
Default Compression releases
im boring from 96 to 103 with stock .045 head gasket and se cast flat top pistons running 204 cams would I need compression releases?
08 street glide
Old 12-15-2017 | 02:37 PM
FLshovelhead's Avatar
FLshovelhead
Food for thought: you'll end up paying about $80 to get your current heads milled for manual releases. I picked up a set of 103 heads off a 2012 Ultra that only had 1,200 miles on it for $200 (shipped) off eBay for my own big bore project. It's already milled for Automatic Compression Release (ACRs), so the cost isn't that much more and I end up with an essentially brand new top end. I will have to grab the factory ACR harness for about $40 and reflash the ECU, but the ECU would have to be reflashed anyways.
Another consideration: if you picked up a second set of heads (any factory 103 should be milled for ACRs) you could send that set out to be ported for $299 at Big Boyz and still be riding your bike while you're waiting for the heads to get worked over. Then after you're done with the big bore project sell your current heads for $130ish to recoup some of the costs.
Old 12-15-2017 | 03:37 PM
I’m from Canada and it’s snowing so I have 3 months yet before I can ride ...I looked on eBay and by the time I buy a used set with our exchange I may as well just get mine machined it will be cheaper. I just thought I’d try to get away from putting them in and if all else fails put a 1.4 kw starter in if I have problems.I was just wondering what people’s thoughts and experiences were with the 204’s in a 103 without decompressors.
flhxkiller (12-16-2017)
Old 12-15-2017 | 03:48 PM
smitty901's Avatar
smitty901
Do it long term it saves battery and starter cost. Harley did not make it standard on the 103 because they were bored .
Old 12-15-2017 | 05:33 PM
0ldhippie's Avatar
0ldhippie
Ya may get by keeping the stock head gasket but a .030 gasket will bump the performance.
Old 12-15-2017 | 05:56 PM
Wodan's Avatar
Wodan
What do you calculate your corrected compression ratio to be?
Old 12-15-2017 | 06:05 PM
Big boyz calculator says with.030 head gasket 9.57.045 head gasket 9.31
Old 12-15-2017 | 06:12 PM
big- mike's Avatar
big- mike
If you are doing cams anyway look at the s&s ez start cams the you don't need acr's that's what I did on my 103 upgrade and they work great
Old 12-15-2017 | 06:13 PM
I already have the cans in the bike I’ve been running them for a year now just want to upgrade to a 103
Old 12-15-2017 | 07:50 PM
Notgrownup's Avatar
Notgrownup
I will tell you that running my 103HO without the ACR and then getting them activated...Oh what a difference...bike start much easier.
Quick Reply: Compression releases
