Compression releases
Old 12-16-2017 | 07:22 PM
Notgrownup's Avatar
Notgrownup
I was doing so much I hated not to put a new clutch.
Old 12-17-2017 | 08:39 AM
2014sportsteriron883's Avatar
So I think I’m going to just install acrs I have a power vision and will I be able to turn these on in the ecm with the power vision?
im going to buy the wire harness and acrs from the dealer
Old 12-17-2017 | 12:33 PM
btsom's Avatar
btsom
Several battery threads have started because people are having to replace batteries every 2 years and they blame the batteries. My experience with a stock 96 is that anything less than a fresh battery will allow hard starts when hot, stopping momentarily, or almost stopping on the first compression stroke. My son's 103 with factory ACRs cranks easily under all conditions for at least 4 years per battery, same battery as mine. If I ever need head work, I would add ACRs just to save on such frequent battery replacement.
Old 12-17-2017 | 12:37 PM
Uncle Larry's Avatar
Uncle Larry
No ACR's on mine ( 2009 FLHTCU ) and I replaced the original battery last spring for "peace of mind" ... I never encountered a hard start/no start situation either.
flhxkiller (12-17-2017)
Old 12-17-2017 | 01:20 PM
btsom's Avatar
btsom
Heat is the suspected culprit in early battery weakening, if not failure. It happens more frequently in the south than in the north. I suspect Southeastern MI is not as hard on batteries as Oklahoma, Texas, Arizona, NM etc. Obviously, one size does not fit all.
Old 12-17-2017 | 07:03 PM
just plain john's Avatar
just plain john
I got manuals installed while I had my heads done. .030 Cometic head gaskets. 9.75 CR after slight head milling. Hardly ever use them, maybe when it's really hot. It's a nice option to have.
Old 12-17-2017 | 07:10 PM
I just found a set of low mileage take off from a 2015 street glide that are cheaperthan what it will cost me to have mine fresher up and ACR machined in them
Old 12-17-2017 | 07:47 PM
Notgrownup's Avatar
Notgrownup
That’s a better deal
Old 12-17-2017 | 07:48 PM
The guy just sent me pictures they don’t have the motor mount holes in the front head
riggermortis
Engine Mechanical Topics
16
06-29-2020 12:03 PM
misfitJason
10-15-2014 06:05 AM
Beedub109r
Exhaust System Topics
20
10-27-2013 07:10 AM
Freeway
03-15-2012 05:25 AM
MoChrome
08-30-2010 02:43 PM
Quick Reply: Compression releases
