08 ultra classic, just put new prewired apes on and have reassembled the bike. Before I put everything back together the bike fired right up. Now that its together I find there is no power to the fuel pump fuse on the block...all the others are hot. There is spark and the bike did fire with some gas squirted into the intake. Im gonna pour over the schematic to this but if anyone has any thoughts on this I sure would appreciate it.
Thanks!
Check the engine run switch on the handlebars connections to make sure they are OK. Then heck your fuses. May have shorted something out when connecting the bars. Next would be fuel pump relay.
I re cleaned all the plug connections again and used dielectric grease on em, replaced all the fuses (just because), turned the key and on it came! Fired right up and Im a happy guy. Too bad its eleven degrees outside...
