2014 Ultra cutting out above 3000 rpm
Was riding in 40 degree weather and will run for a mile or two ok. Then it starts missing and will not rev past 3000 rpm. This may be coincidence but I ran the fuel low just before it happened. Was able to put 5.7 gallon in the tank. Acts like it is starving for fuel. Local guy thinks its the TPS. Checked the codes and found none. Another guy says a bad battery will act like this. I don't have a check engine light. i am stumped. Any ideas. I ordered a fuel filter on the off chance that it is blocked.
Mine throws code P1510 (Limited Performance) will run up to 3000rpm's then bog if I try to run up past that. But mine throws the check engine light. I can shut her down and restart her...and if I don't turn my front end sharp right...the check engine light stays out and it runs normal. It's something I'll address this winter...it's either the TGS or TP sensor.
Good luck and let us know what you find.
smat
smat
guesscrazy (12-16-2017)
Before you spend money and time on doing the filter take it somewhere and have the fuel pressure checked. Also check the dtc codes and see what's up with those. It may be a sensor connector or sensor not functioning properly. I've ran my bike very low on fuel and not had any problems.
