Lowering an Ultra
RE: Lowering an Ultra
Heres a couple of questions I always have about lowering a bike. How does reducing your ride height and decreasing ground clearance improve handling? I scrape enough as it is at the stock height, so how is this beneficial? I'll admit it looks cool, but I'd rather not trade peformance for looks.
ORIGINAL: Road Toad
OK, anybody lower their Ultra? Did it help handling? What did you use and what is the cost? How much did you lower it?
I know, lots of questions.
Just want good info before I spend a bunch of money with little or no benefits.
The Burley kit is a good one. You'll need to have a Dremel tool or die-grinder handy to smooth the ridge on the rear portion of the frame where the two peices clamp together for a true, solid fit. Not a big deal to accomplish.....one removes just a smidgeon of material for a perfect fit. Many of my friends have done the same thing. No worries and it works. Very solid.
Your other choice is a shock replacement. Most use a Progressive shock and they come in many lengths. Buy the Heavy Duty if you go that way.
Hope I helped!
Will look into that Burly kit. Looks like what I am looking for. I would think a lower center of gravity would be a good thing, and I don't hit the turns that fast on my Ultra, so a little lower wouldn't hurt me there. Just make it easier for the wife to get on and off and better leg distance for me.
Thanks guys.
Thanks guys.
I don't have an Ultra but a Standard,and I have the detachable tourpak. I switched to Progressive 412 shocks, 12" vs the stock 13". I don't notice any difference in the handling. If I had to do it over I'd go with the heavy duty springs instead of the standard springs. I ride with them cranked all the way up. At any setting the ride is better than stock, but at the lower settings it seemed to bottom out on some of the really harsh freeway bumps.
