Clutch Housing Replacement
I own a 2012 FLHTCU and I am in the middle of replacing the clutch discs, clutch housing and chain tensioner. The oem clutch housing appears to be riveted to the clutch sprocket. Do I need to take this assembly to a machine shop and have the rivets machined off in order to separate the oem clutch housing from the clutch sprocket or can I simply drill the rivets off to separate the parts? I'm replacing the oem clutch housing with a Barrett Scorpion Billet Clutch Housing which is to be attached to the clutch sprocket by way of bolts. Thanks to all for your suggestions/advise.
ColoSpgsMark
01-05-2010 08:22 PM
