Performance baggers
#242
Garrett
#243
The Dyno operator did a few runs with and without that center grate/screen. It picked up a tad bit of power without it. Anything I'd feel under my ***? Probably not but at that point why not get all you can? And I actually think it looks better without it. And thanks for the comment!
#244
Having said that , while I prefer the looks of the wall, when I sat on the lucky daves it did feel a hair more cushiony
#247
2013 CVO Road King 117"
- Suburban Speed 117” cylinder/piston kit – zero decked, Mahle 6.6cc domed pistons
- Heads by Larry’s Motorcycle and Machine – CNC ported, 2.1 intake, 1.65 exhaust, AV&V beehive springs, AV&V bronze guides
- HPI 58mm elliptical Throttle body
- Marren 5.0mm matched Fuel injectors
- Cycle-Rama 630i cams
- Screamin’ Eagle adjustable pushrods
- “RockOut” rocker lockers
- S&S Premium lifters
- S&S TC3 oil pump
- S&S 3-piece crank assembly
- S&S piston cooling oil jet kit
- Baker +1.5qt high capacity oil pan
- Screamin’ Eagle “Lefty” crank bearing
- Screamin’ Eagle Agitator breather with center screen removed
- Externally vented crankcase
- D&D Boarzilla exhaust with ghost pipe
- Barnett Kevlar clutch
- AIM VP-SDR clutch lock-up
- Screamin’ Eagle Big Twin Compensator
- 11 to 1 compression, 195/195 CCP
- S&S TC3 oil pump
Beautiful bike, inside & out.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
#249
It definitely gets me down the road. This one is modest compared to some of my other online friend's kings! There are some monsters out there .
#250
The following 2 users liked this post by FNGonaRK:
ROCKOUT Rocker Products (04-11-2018),
stm250 (03-10-2021)
