Performance baggers
#1301
haha, I know I've bugged you a few times over the years between this bike and your old lowrider when I had my S. And thanks, it's much better than spending 200 more bucks for an aftermarket fender.
DynaKid94 (04-22-2021)
#1302
Don't know how many miles you have on your bike but my 07 had bad wobble which a was able to fix by replacing the swingarm bearings. Instead of self aligning spherical bearings (stock) I put in 2 regular ball bearings per side that I purchased from the Sta-Bo guy. The Sta-Bo guy said that the stock bearings are typicaly good for 40,000 miles of regular riding, hard riding will wear them out quicker. When i replaced mine I had about .010-.015 play in the spherical bearings. I wasn't able to hit 85 without the death wobble now I have gone considerably faster (115-120) with no problems.
aroacha5446 (04-22-2021)
#1304
The following 3 users liked this post by Wheelup:
#1306
#1307
#1308
All I'm getting at with the belt tension is that my service manual shows (2) different belt deflection values.
Low profile shocks (I'm assuming this means 12") calls for 1/4" - 7/16" of deflection
Standard shocks (I'm assuming this means 13") calls for 3/8" - 9/16" of deflection
I'm not a math genius, what's the trend here? Where would this line up with total deflection for a 14" shock?
#1309
aroacha5446 (04-23-2021)
#1310
Again, not a mathematician but I think if you followed the trend of that chart into a 14" shock you would be given a deflection range of 1/2" - 11/16"
With that being said, I'll just aim for 9/16" which will be (9) of the notches in the belt deflection window.
jyd83 (04-26-2021)
