Another Andrews 48 Cam Thread
Trying to put together a shopping list for a Cam Change.
2009 Road King Stage 1 with PV 32,000 miles.
I would like to go add cams and do the job myself,
Amazon has Andrews 48H for $211, doubt I can do better than that.
I知 thinking lifters SBC? S&S? Woods? Trying to do this as cheap as possible without risking troubles. What kind and where to buy?
Cam install kit with bearings, where to buy?
Adj Pushrods/ Tubes. What kind and where to buy?
Blind puller from Autozone okay for Job? I知 reading a lot about the blind puller for removal and used cams to install?
The more I read threads on this subject the more confused I get on what route to take. The only thing I知 currently solid on is getting the 48痴 from Amazon.
Trying to find the best places to go to put this together on a budget.
1 Andrews 48H - Amazon $211
2. Adj Push Rods - where to buy how much?
3. Cam Kit with Bearings - where to buy how much?
4. Lifters - where to buy how much?
5. Do I need a specialty tool or is rental of a blind puller from Autozone cool?
https://www.harleypartscheap.com/
I installed a couple bikes using a free auto zone blind hole puller and cams. Also went in through the top and prefer this method. However, with the 57's smaller base circle, I ended up using adj's.
Also, the cheapest parts are buying them here and on CL, just have to take your time.
Update:
https://www.hdforums.com/forum/multi...ers-190-a.html
23Seven (11-13-2017)
Good luck with your project, I'm sure you're gonna love the new found power.
