LED headlight upgrade
Received 14,668 Likes
Easy fix. Put stock or better light in bike. JK, sorta. Have had the same issue with last bike. Sucks as the light was not cheap. But wasn't a Daymaker so I paid the price and almost never played FM again as long as I had the bike, about a year. Other option is as I did, only listened to iPod. Fact is many such lights induce interference. And don't waste money on what you think is a better antenna like I did.
Many of the knock-off LED headlights have high EMP which affects the radio signal. I have the Sunpie and it affects reception. I use my USB stick all the time, so don't really care. No buzzing though for the radio i do get. You may want to check out the Hogworkz LED or JW Speaker 8700 Evolution 2, more than most knockoffs, but less than Harley stamped one.
2016 FLHTK, avoid all LED - Keep a minimum electrical load
2016 FLHTK, avoid all LED - Keep a minimum electrical load in order to make your generator voltage regulator working? I hook-up a stop bulb to a cigar lighter connector and underway, I notice the radio reception went fine as soon as I connected it to the lighter plug! LED removes an inportant electrical load from the bike sytem (not enough is left?). I found that putting back the original two forward flasher bulbs was sufficient to maintain the radio in perfect reception! Hope this could help others. Salutations du Canada Québec Français
usmc68
11
07-21-2019 10:54 AM
