tour pak lights
Old 11-11-2017 | 12:36 PM
joecompy's Avatar
joecompy
1st Gear
Ok, here’s my situation, 2014 Ultra limited, tour pak lights don’t work but my brake lights on the tour pak and the blinkers work. The only one that’s not working are the tour pak driving lights that are suppose to stay on while ignition is on. How can the same lights work for everything else, but not the driving lights. Now I was told by an HD dealership that factory says when the LED go out you have to replace the whole unit across the back of the tour pak. It not a fuse or a pint he’d wire.... does this make sense or I’m I getting screwed. I just can’t believe I’m gonna have to spend $300 for a new light bar
Old 11-11-2017 | 01:05 PM
joecompy's Avatar
joecompy
1st Gear
Smile
Originally Posted by hbsoldier3
Just to clarify your question, when you turn the ignition on the light bar does not illuminate?
no they do not
Old 11-11-2017 | 02:55 PM
grbrown's Avatar
grbrown
Lightbulb
As mentioned before, it is quite likely there is a poor connection or damaged wire. You need to get down and dirty to inspect and test your lights - or find a local indy who can check it out for you.
Old 11-11-2017 | 11:12 PM
wmprof's Avatar
wmprof
I would check all fuses in fuse block per MilesofTexas. I would also pull the tour pak liner out of bottom of pak and check all wiring there, especially ground wire.
Doubt the unit is bad, if LED's light at all should be fine. Another issue if not on in run mode, but work for brake/turn. Tech is just pissing in the dark as normal. Parts replacer, not mechanic.
Old 11-12-2017 | 10:51 AM
lorddj's Avatar
lorddj
Not a fuse. Using a multi-meter check the solid blue wire going into the TP light bar, this is the running light. I doubt you are getting 12v at the light bar. You might also check the other (turns and brake) to confirm but because they work I'm sure you're OK there.
I had this same problem and I found the solid blue wire was pinched.
not yours
12-02-2017 06:42 PM
DXHD $100
03-01-2012 07:41 AM
JHC210
11-14-2011 09:09 AM
JHC210
10-30-2011 02:50 PM
TxDeuce
03-04-2011 09:56 PM
Quick Reply: tour pak lights
