Primary case oil change
Old 11-04-2017 | 08:13 PM
Gearup's Avatar
Gearup
Stage III
Default Primary case oil change
I've watched a ton of videos on how to change primary case oil. They all start with "pull the drain plug" there is my problem. THERE IS NO DRAIN PLUG on my 2006 ultra classic flhtcui.
Old 11-04-2017 | 08:20 PM
Tynker's Avatar
Tynker
You do have a drain plug, look at item # 10;
http://partsfinder.onlinemicrofiche....CASE%20HOUSING
Old 11-04-2017 | 08:27 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
By now, He should be "By golly, well there it is".
Or like an old friend of mine would say, "Well, it wasn't there while ago!"
Eric Moore's Avatar
Eric Moore
Yes it has one.. I had a 06.. unless you have some aftermarket outer primary.. then I even bet all those did as well
Old 11-04-2017 | 08:32 PM
Gearup's Avatar
Gearup
Stage III
Default Awesome
Thank you guys. My old eyes thought that was just another screw to hold the case on. I went and checked and sure enough. #10 is it. Lol. Thanks again
Old 11-04-2017 | 10:02 PM
hbsoldier3's Avatar
hbsoldier3
Actually, it is number 21, the seal is number 10. Anyways, I always replace both when servicing my 04 RK. Due to my primary being some stripped. HD sells the two together for like $4 bucks.
stuart1270 (02-02-2020)
Old 11-04-2017 | 10:05 PM
TheGrandPoohBah
We just poppin' yer chops, glad you found it.
Old 11-05-2017 | 08:35 AM
beanoboy's Avatar
beanoboy
Don't worry about it, I had the same problem finding it on my 06 R.G....b.
Old 11-05-2017 | 02:59 PM
470004's Avatar
470004
Agree!
HoldFast71
Oil Archive (no new posts)
07-27-2012 07:32 PM
freebyrd
06-06-2011 05:50 PM
Robtarra39
04-25-2011 06:58 PM
Streets of Fire
10-29-2008 08:21 AM
yota
11-23-2005 04:03 PM
Quick Reply: Primary case oil change
