Mixing Tire Brands
Hey all. I'm the proud owner of a new-to-me 2009 FLHTCU with 14K miles and couldn't be happier. I came from a VStar 1100 (2005) and it's like night and day haha. The dealer put a new Avon tire on the back, but the older front tire almost seems to have a flat crown on it. Going into curves it seems to ride on the edge of the crown and feels like it wavers between the sidewall and the flattened out part of the tire. It doesn't feel smooth through the whole radius of the turn and the front wobbles a little bit. It's almost like the front tire shaped into more of a car tire shape. I hope I'm describing this so it makes sense....I'm not sure if it's the original tire or not, but I'd like to replace the front tire because of this. I had a set of Metzler 888s on my Yamaha and tread wear was phenomenal! Great grip too. I'd like to put an 888 front tire on it. Has anyone had any issues with different tire brands on front and rear? I've always changed mine as sets in the past so I've never had any experience with it. Should I just get a matching Avon front and switch to the Metzlers next tire change? Thanks.
Avon makes a good tire. So does Metzler. Tire brand doesn't make all that much difference as long as the tire type or category is the same. Chances are your Avon is a touring/cruiser type tire. So stay with that. Personally I stick with the same tire brand and type just because I like things to match.
Mixing brands doesn't matter in the least to the bike.
To the rider? Well that depends on the rider. Some just like to see the same name when they wash the bike. Some have a, idk, an ocd thing about it.
As long as those things don't worry you go with what you have experience with and like.
Good call on the cupping larsfum. After reading up on that it seems that's most likely the issue. I've read where that isn't necessarily a bad thing or a need to change the tire soon. Since most of my previous rides have been around 530 lbs, I've never experienced it on those bikes. It seems to be a fairly common issue on heavier bikes though. Might not need a front tire after all?
I recently replaced the rear with an AVON, but the stock Dunlap up front sill has a bit of life yet. No issues thus far.
As stated, your front tire is probably cupped. I would just replace it with a matching Avon., or if you prefer the put on the Metzler.
Ran the Avons on my bikes for lots of years, so I'm partial to them. Good grippy tire, handles wet and dry roads great, and seams to last as long if not longer than the Dunny's. Plus much cheaper than buying a new set from the dealer.
