What size socket do i use on my axle nut?
Old 10-26-2017 | 07:14 PM
470004's Avatar
470004
Motion Pro 36mm axle socket.
OLD 96 (03-06-2024)
Old 10-27-2017 | 06:05 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by Joe12RK
1 7/16 works too
Originally Posted by grbrown
That's a little over-sized, it is actually 36mm, as mentioned above. In my modest experience, that nut can require some serious effort to undo, if it has been left undisturbed for a long while, so a good fit is a good idea!
Had to use a 1 7/16 when I could not find my 36mm.
It worked without any damaged when torquing the nut.
Of course a 36 would be the correct one to have.
Old 10-27-2017 | 11:03 AM
Sparkee...'s Avatar
Sparkee...
I was actually surprised to find a 36mm socket at the local Canadian Tire store (hardware type store) here. It was the only larger metric size they had so I suspect it they stock it just for the Harley riders in the area.
Old 10-27-2017 | 01:03 PM
roussfam's Avatar
roussfam
Just picked one up there about 3 weeks ago, i was surprised they had one, price was right too
Old 10-27-2017 | 04:31 PM
LQQK_OUT's Avatar
LQQK_OUT
Not sure how true that is. A 36mm socket is used to remove the oil filter cap on my VW.
Old 10-27-2017 | 04:34 PM
roussfam's Avatar
roussfam
And I think it's a common size for the axle nut on FWD cars
Old 10-27-2017 | 04:38 PM
Uncle Larry's Avatar
Uncle Larry
C/V joints ( front axle fwd cars ) are generally 32mm and 36mm
Apendejo (10-28-2017)
Old 10-27-2017 | 10:10 PM
steelerdude1's Avatar
steelerdude1
I’ve been using the standard sockets on the axle nut for years with no issue. I’d have to look but thinking 1 7/16 is the size.
Old 10-28-2017 | 11:11 AM
btsom's Avatar
btsom
Originally Posted by Ex-Leftcoaster
Might be quicker to measure with a decent ruler or just see which socket fits.
I have been a do-it -yourselfer for over 50 years and have no idea if a nut is measured from flat to flat, point to point, or some other way. What I DO know is that to measure either way with any accuracy with a RULER would require the nut to be off the axle. It being ON THE AXLE seems to be his current situation, so a caliper would be more appropriate.
Old 10-28-2017 | 12:14 PM
svarnster's Avatar
svarnster
Quick Reply: What size socket do i use on my axle nut?
