Do I really need to tune my bike?
I'm sure this question has been asked many times, but I am looking for help from those who know more about this than I do. I just bought a 2015 Road King. I am about to add some Vance and Hines True dual headers and slash cut slip-ons. I don't really want to change the intake, so if I just change the full exhaust, do I need to do a tune on the bike? I don't want to do a tune if I don't need one. I would rather spend that money on other things for the bike. Please help!
dmorales24 (10-19-2017)
Enjoy that Road King.....it's one of my favorite HD's....next to my Road Glide it's #2.
Second thought after seeing Rob's post above.....he may be right about that. If only mufflers, then "no" is the answer to "need". But headers and all.....he may be correct.
You're allowed to install those pipes, ride it, and decide for yourself if you need a retune or not. There's a good chance that you don't. You may get a little popping on deceleration and the occasional burp on take-off. But if the bike isn't pinging, knocking, running horrible, etc. you're ok.
The following 2 users liked this post by foxtrapper:
DanRC (10-30-2017),
As mentioned, the fact that you are swapping head pipes to a true dual will effect the AFR's making them even leaner than they are now. These come from the factory pretty lean in order to meet EPA emissions. Lean means heat, sometimes hesitation and being more susceptible to pinging. If you are not planning on making any other performance modifications than a simple programmer will work fine.
Have a question for you. Are you using the power duals or the dresser duals? If you go with the dresser duals don't be surprised if you end up with a slight loss in low end grunt. If you were thinking dresser duals might I suggest either the power duals or one of the many 2-1-2 head pipes. They will do a better job maintaining the low end power. Low end torque is what gets these bikes moving. Regardless, enjoy the new ride.
Neil
RDMC
Neil
RDMC
The following 2 users liked this post by Neil:
dmorales24 (10-19-2017),
RATFINK53 (11-04-2017)
