Battery not charging ultra classic
I have a 1999 ultra classic battery isn't charging no voltage on the gauge. I have put a new battery in it replaced the rectifier and tested the voltage coming from the stator all is well but still get nothing to the battery and info would be appreciated I'm stuck please help really want to ride.
Welcome to the forum from central Texas.
You did what many do which is to replace parts before diagnosing the problem.
In the electrical subforum, there are threads called "Sticky"'s at the top of the subforum. Below are two that help diagnose charging system issues.
Testing the charging system
Additional testing of the charging system
I left out some info this problem started after I installed a new radio and amp like a bone head I installed a regular car amp not a bike amp didn't think it would be a problem still not sure if that's what caused it maybe this will help give you guys an idea of what caused the issues I. having thanks
Welcome to the forum!!
It seems what you've done so far has been haphazard at best. Throwing parts at a problem without a proper diagnosis is expensive and, as you've found, often in effective.
Once you have followed the instructions in the stickys above post back what you have found and we can be far more help.
Tuckers Dad
10-17-2017 03:32 PM
