Ignition switch alignment tool
Old 10-10-2017, 09:33 PM
Kyle C Kirk's Avatar
Kyle C Kirk
Kyle C Kirk is offline
Default Ignition switch alignment tool
Wondering if this would work on a ‘17 RG Special? I removed the switch and cannot align the tumblers to reassemble.
Any info or advise would be greatly appreciated. Thanks.
Old 10-11-2017, 05:42 AM
cookiemech's Avatar
cookiemech
cookiemech is offline
Believe the answer is "no". The ignition switch changed somewhere around 2014 and a different tool is needed. I know that the tool I have for my previous 2009 Ultra will not fit my 2017 Road Glide Ultra (which should be the same as your RG), so I bought the new tool.
George's Garage has the new tool (659950) for a few dollars less than I paid, though it's still not cheap:
http://www.georges-garage.com/chassis_tools.htm
Note that the older tool George's sells corresponds to the H-D part number shown in the eBay listing above.
Old 10-11-2017, 06:02 AM
Kyle C Kirk
Cookiemech, thank you for the info
Old 10-11-2017, 07:46 AM
Veekness's Avatar
Veekness
Veekness is offline
I've had to use a long, straight screwdriver to do that alignment job a coupla three times...even when I've kept that tool in place during the job! It's just a matter of hit and miss...I've got the George's Garage version, looks similar to that one.
If you've got misalignment, grab you a cuppa, and that screwdriver, and a flashlight, and suss it out...you'll get 'er done...might take a while, but you will! I've done it, like I say, more than once...
Old 10-11-2017, 03:31 PM
470004's Avatar
470004
470004 is offline
Received 16,345 Likes on 6,767 Posts
Jims Tools make a Ignition switch housing alignment tool for 2014 and up, part #944.
Old 10-11-2017, 03:33 PM
cookiemech's Avatar
cookiemech
That's the one I bought, and it worked perfectly on my 2017 RGU.
Old 10-11-2017, 11:08 PM
Kyle C Kirk
Thank you all for the info. Found a shop that had the Jim’s #944 and like stated, worked like a champ
Old 10-12-2017, 12:36 AM
hamah's Avatar
hamah
hamah is offline
Glad it worked for you but did you try to use a flat screw driver as described above? Works great and you probably already had one in your tool box.
Old 10-12-2017, 02:24 AM
ubreal's Avatar
ubreal
ubreal is offline
I use a piece of 1/4 copper tubing pounded flat work great.
Old 12-08-2017, 04:40 AM
EdwardToscano's Avatar
EdwardToscano
EdwardToscano is offline
Kyle did you try that tool from Amazon, did it work. I’m having the same issue on my 207 Road Glide the tumblers are out of alignment and forks are locked can’t get the ignition cap back on.
Quick Reply: Ignition switch alignment tool
