how do I? get to the battery
Received 2,528 Likes
Received 4,553 Likes
Every body is helpful but I still don't know if I can just pull those connectors off or if there is some trick to it. they don't slide off or pull off easily. As you can see in the you tube video, dufus was unable to pull them off so he just lifted the tray with the connectors still attached, which probably made the process more difficult.
IIRC -
Pull your main fuse.
Unplug the 2 connectors on the left side of the cover (pry up on the latching tab to unplug).
This should give you access to the mounting tab latches for the unplugged connectors.
Release the tab latches & slide the connectors free.
Remove bolts for the ECM mount (the cover) & lift out of the way (should be able to do that w/o unplugging the ECM).
(Out of town & can't check either bike or service manual.)
coop creek (10-07-2017)
Those other connections have a tab (visible in the video) that releases the top part (left side in the video) that will pull apart when the tab is pushed in. The bottom part (right side in the video) is "hooked" onto that tray by sliding into a groove-like attachment point that is either moulded into, or snapped into the tray. It's easier to remove and replace them from the tray when the connectors are apart.
he didn't show the battery removal... the only part that can be a bear... if you search, there are numerous suggestions of tricks to get out an old battery and/or things to do when you install a new battery, that will make it easier to get out.
After I replace my battery, it's a good opportunity to check those connections. I inspect the connectors (pins), clean (with electrical contact spray) and put a small amount of dielectric grease on the connectors before I reassemble them.
I've had my bagger five years and I replaced the OEM battery a little less than a year ago. The next time I remove the battery, I will probably remove, check, clean (with electrical contact spray), and use a small amount of dielectric grease on the ECM connections. I just don't like to mess with them a lot. They seem a little more fragile than the other connections...
Good luck...
