Frequency of oil changes....NOT ABOUT THE OIL
Old 10-08-2017, 10:58 AM
TXPHNDL's Avatar
TXPHNDL
TXPHNDL is offline
Originally Posted by bill from tn
Does no one else think like me that the unfiltered primary that has wear plates inside and cools the stator, lubes the primary chain and compensator needs a fluid change at least as often as engine oil?
I get little or no particles on the oil pan magnet but always have fine stuff on the primary plug.
For what it's worth, the transmission oil drains as clean as when put in new.
Agree, although I have no technical expertise on transmissions. I feel better about it and it’s my $ for the quart of fluid.
  #52
Old 10-08-2017, 11:14 AM
xcbullet's Avatar
xcbullet
xcbullet is offline
Yes and aluminium that don't stick to magnet may be the cause of some stater failure. Is why I like to keep it clean.
  #53
Old 10-08-2017, 11:40 AM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
Like I said I go 3,6 and 10k normally. I ran a test this last time extending the change intervals. What I found is I'll stick to that mileage. At 52k I use no oil at all up to 3k. Between 3-4k I used 1/2 a quart. I changed the primary at 3k once and it looked like I just put it in. However at 7k it was a tad darker than I like. Also at 3,6 and 10k it helps keep everything clean.
  #54
Old 10-09-2017, 11:08 AM
torchmaster's Avatar
torchmaster
torchmaster is offline
Oil and primary every 5000
Tranny 15 - 20 k
  #55
Old 10-09-2017, 01:54 PM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
im perplexed on the frequency of the primary by Harley. in my way of thinking, the primary should be changed more often than the other two holes. It gets the most contaminated with the clutch fiber plates. look at all three drain plug magnets. the primary always has the most crap on it. my crank and transmission have practicaly nothing on the magnet. Even if your oil hasnt broken down yet, it still has contaminants from things meshing together i change out my primary religiously every 3000 along with my crank. trans every 6k. i drain and just pour in 38 oz every time.
cybricon
Oil Archive (no new posts)
42
09-03-2018 09:59 AM
Hair53
05-15-2013 10:33 AM
RogueRyder1
07-27-2010 06:41 AM
titus3:5
04-28-2008 08:44 AM
Quick Reply: Frequency of oil changes....NOT ABOUT THE OIL
