Auto Tune ordered
Old 09-26-2017 | 09:42 PM
cajun1957a's Avatar
cajun1957a
I forgot to say I'm running V&H true duals they have 18 mm bung holes in the already which are presently capped. And Dave about the wide open throttle in 3d gear, I don't do that I let off the throttle first before I pull in the clutch.
randy
Old 09-26-2017 | 11:50 PM
KumaRide's Avatar
KumaRide
Originally Posted by cajun1957a
Ok so I took the plunge and ordered an At-100 Auto-tuner for the PC5. I have an 03 Road King Classic. I have been mulling this over and over and talking to people on here and elsewhere for advice. My skoot runs pretty good now but I thought after putting in 510 cams I would feel a noticeable difference. I feel just a little, very little and dyno tunes are out of the question from where I live let alone this is a touring bike, not a hot rod. I've seen them do the dynos and it cant be all that good for the bike if they have to do multiple runs. So I guess I will see if the money I'm paying is worth it. $625 Canadian. Ya I know. It should be here in a week. I was considering trading my bike on a CVO of the same year but a lot of people said to keep what I have as I know what I have into it. I'll let everyone know how it works out.
Randy
2003 Road King Classic
25,000 miles (41,000 km)
S&S 510 chain cams
Kerker Original Slip-ons
SE high flow breather
Power Commander 5
Is your bike still an 88"?
Old 09-27-2017 | 12:47 AM
Tarkus60's Avatar
Tarkus60
Veteran: Marine Corp
I was looking at the thunder max with auto tune.
Old 09-27-2017 | 12:48 AM
rhuff's Avatar
rhuff
I swear, people ride harley's like they are made of porcelain. Dyno is just fine. And a wonderful way to break in a new build as well.
Old 09-27-2017 | 01:07 AM
davewear's Avatar
davewear
randy
So you're decelerating with your clutch in? Doesn't make any sense to me but whatever....
Old 09-27-2017 | 01:24 AM
lightweight bob's Avatar
lightweight bob
Default Base map ......... +1
Originally Posted by FlaHeatWave
Having a good basemap for your bike/combination is crucial...
The PC-V / Auto worked well for me for a few years...
My godson found that out the hard way. BMW s1000rr with PC5, canned map and auto tune module. Hicup off the
bottom and other assorted fueling problems. Took it to M Racing to get it squared away. Base map was too far off
for the auto tune to correct. A good base map, verified the auto tune was working and all his problems went away.
Old 09-27-2017 | 06:26 AM
cajun1957a's Avatar
cajun1957a
Dave, I roll the throttle back and then pull in the clutch when decelerating to a stop sign etc. I don't let the engine totally pull the revs back down. Ive seen dyno runs go full bore then the guy just lets go of the throttle. That's not the way I ride in real live, I roll it back and then as I'm coming to a stop or what ever I may pull in the clutch. I did NOT mean pull in the clutch at full bore and let it drop.
randy
Old 09-27-2017 | 06:34 AM
oldhippie's Avatar
oldhippie
Originally Posted by oldhippie
Cajun, what head pipe are you doing with, I don't think you want to use the stock set up you have in that picture for the sensors. Make sure you have a head pipe that accepts 18mm sensors.
Fuel Moto is the only one I know of that actually makes and sells a 2-1-2 head pipe that goes under the frame for pre 2009 bikes. I'd definitely be looking at that for your bike. Did you buy the Autotune kit from FM? They'll pre load an good starter tune which you'll want for the PC5.
I take that back, you can use the stock pipes, the new sensors will screw right in where the old came out.
Old 09-27-2017 | 09:21 AM
Tarkus60's Avatar
Tarkus60
2003 did not have O2 sensors....
Old 09-27-2017 | 01:02 PM
cajun1957a's Avatar
cajun1957a
Tarkus60, true it did not have O2 Sensors but Vance and Hines true duals do and that's what I put on the 2003 RKC.
randy
Quick Reply: Auto Tune ordered
