08 Road King Classic which has started to act strange
I have an 08 Road King Classic which has started to act strange
When I turn on the ignition my HIGH BEAM indicator lights up and I have no head light high or low beam, at other times my High beam indicator will light will come on at start up and at some point while driving I notice it will go out, not sure if the headlight was on or off.
Does HIGH BEAM indicator come on to indicate a burnt out headlight ?
Does this sound like a short ?
Is there such an item as a HIGH BEAM relay, and should be replaced
THANKS
THANKS
YOu may want to pop the headlight out and look at the connection. I just had to replace my connector about a month ago. Mine was loose, caused it to over heat... I think the connector was about 10-15.00 from Moco. You may be able to get same connector from a local auto store for cheaper (maybe)
Dale_K
Electrical/Lighting/Alarm
03-05-2016 07:42 PM
