Loose shifter linkage
Yup its me again. I have read elseshere about the shifter linkage at the tranny becomes loose on the splines on that arm wear. Not a lot of room in there and pulling the inner primary isn't too desirable. I have a 1/4 inch allen bolt currently on it and I have snugged it down but I'm afraid to reef on it as it may strip the threads or worse break either the allen bolt or the arm housing itself. I can see it move a good 3\16 or an inch before it catches. I have also read about an aftermarket two piece arm that can be had but its not cheap in any respect. And another guy said to just remove the allen and put in a grade 8 bold and torque it down big time. For those who have done that if any, does the bolt go all the way through with a nut on the other side or is the arm and threads strong enough to withstand a good twist to keep it tight? That little 3/16 of movement equates to quite a lot at the shifter pedal not to mention the rattling. I have enough noises that I don't need another.
Advice guys please
Randy
Advice guys please
Randy
Run the old bolt up & down couple times spraying with brake clean in between. The put a new bolt in with blue loctite. Torgue the **** out of it till u think it's going to break. Check to see if it's slipping, if is tighten more. If it breaks before u get it good just to worn out to fix that way. I caught mine early enough that it worked for me. Eventually I replaced it all with Baker stuff as rebuilt the whole trans.
Received 49,865 Likes
I pulled the allen bolt out and put in a grade 5 bolt as that's all I had at the moment. Fine threaded that is. I run carb cleaner in the hole then put a little lithium grease on the bold and torqued it down. Seems pretty good now. Less than a 32 of an inch of play and I attribute that to the internals of the tranny. (in neutral) We will see how long it lasts. Next is bushings in the front for the pedal itself. I hope its not to big a deal. Cant wait for my service manual to come in. Was told at least another week.
randy
randy
Advice guys please
Randy
Advice guys please
Randy
Leon. is there supposed to be any play in the bushings at all. There is movement but slight. of course that compounds its self at the other end of the arm. An how do you get them out. the rear you can drive through, how do you get the front one out it will be pushed further in wont it?
randy
randy
Draw a straight line across lever and shaft with a sharpie.
Then use a mirror to see if line breaks as lever is moved.
Video does nor show much since lever must move with shaft.
If needed:
If you have a 2012, a 6 speed then primary has a factory dent (relief) on back.
Dent/relief on back of primary allows for removal of the lever.
Slide lever across shaft and then tilt lever to remove without removal of primary.
Must remove bolt first.
If needed:
