Andrews 48h cams
Andrews 48h cams
I recently replaced my stock cams with andrews 48h cams also put screaming eagle oil pump and cam plate, have a screaming eagle big air breather, screaming eagle tuner, put s&s premium lifters, and new bearings for the cams, it was an easy install but cant get the tune right and its building a lot of pressure also blow out a push rod o ring this is after are local Harley dealership tuned it as well runes alright but can t figure out why it's missing in second and in fourth gear at 3000 rpms , does anyone have a map or advice to what need to be done I'm stuck and wanna ride.
My understanding is the SE tuner isn't nearly as as good as it used to be due to the EPA stepping in and dictating that it can only make changes that stay within their regulations. I don't think the settings needed for the 48's fall within those regulations, so getting a "good tune" with it might be problematic. Of course this is my understanding, and probably someone with more knowledge of these things good provide more insight.
i have 48s in my 2010 roadglide 96 with true duals and cvo slips ons
it is tuned with an fp3 and gets great fuel economy, runs strong and pulls to the red line.
with oil puking out of pushrod tubes, does not sound like its just the tune
79roadster
Engine Mechanical Topics
16
07-26-2019 08:46 AM
