Broken throttle body
Has anyone here used a S&S throttle body? Took off my air cleaner today. And noticed a crack in the bottom right bolt hole. The piece will actually come out, if I remove the bolt. Must have over tightened. Sh*t happens. So it has to be replaced, hence the need, to replace. The bike is a 2004 FLHTCUI, with a SE 103 kit. I was going to the 52mm kit. Will this work?
kyleplusitunes
12-01-2011 12:10 AM
