broken clutch cable
Old 09-05-2017 | 01:22 PM
dodger413's Avatar
dodger413
a good reason to bring back the "mousetrap" mechanism of the panhead years.
clutch cable breaks, tie a piece of rope to it, or by hand.
the new 2018 clutch cable seems to be a good innovation, but wouldn't help in a snapped clutch cable situation , i guess.
Old 09-05-2017 | 07:02 PM
Veekness's Avatar
Veekness
Originally Posted by cficole
It's coming back to me a bit more now. Planning the route as you go, so it's always right turns, helps a lot. Three rights instead of a left.
​​​​​​​If you can plan, it helps...sometimes ya gotta mix in some uies to turn left
Old 09-05-2017 | 09:32 PM
cficole's Avatar
cficole
It was easy where I was, Chicago and suburbs, flat land, big grid of side streets.
Old 09-05-2017 | 09:34 PM
rhuff's Avatar
rhuff
I broke mine 25 miles from home north of Minneapolis while out in the countryside. I made it almost all the way home (about 7 miles shy) when I finally couldn't time a light. I was soooo close to making the interstate which would have swung right by my place :/
Old 09-06-2017 | 08:30 AM
craigffb's Avatar
craigffb
I've had them break a couple of times. Once you get going you don't stop until you get home. It takes planning and *****. Otherwise it's tow time.
I just got lucky and there wasn't any traffic so I could roll through the STOP signs.
Old 09-06-2017 | 09:08 AM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Broke mine on my 77 low rider back in 77. Rode into parking lots , circled till traffic was clear then pulled out and proceeded home. Also started in 1 st with me off seat then sat as it started pulling. LOL Made it home but started changing regularily to prevent recurrence. New cables shouldn't need lubing. People lube and end up causing more issues .
Old 09-06-2017 | 09:59 AM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
Don't understand how you couldn't shut down the engine either. Kill switch does a fine job, as does the ignition switch.
If I've actually got to stop without a clutch I usually kill the engine as I approach with the stop. I like to be in 1st gear on a bike, or neutral in a car.
For starting, I simply use the starter motor and get it going while lurching along in 1st gear. It's a bit rough on the starter motor, but usually they can do it.
Shifting a bike without a clutch is easy, it's a dog box, so as long as you're not under load, it'll shift easily. Cars and trucks are a little harder and I'll frequently grind a bit trying to match the engine rpm.
Old 09-06-2017 | 11:48 AM
voodoodrug's Avatar
voodoodrug
I left a dealers parking lot after some service years ago with no clutch cause they never finished the last step of takeing in the slack.... low traffic ride home so just sucked it up,not fun but make the split second decision to just get out of there...
Old 09-07-2017 | 05:51 PM
slvdout's Avatar
slvdout
I broke one this spring, same result as everyone else, I timed lights and ran stop signs.
All Aces
01-29-2018 11:29 AM
Clammy
08-25-2017 05:51 PM
trackadaptor
07-09-2012 10:42 AM
Roadie09
07-15-2010 09:15 PM
skos
10-23-2008 03:46 PM
Quick Reply: broken clutch cable
