No oil pressure
No oil pressure
My 2013 RG Custom will not start. Was working fine when I last rode it. The battery is good and oil level is good. It sounds like the oil pump energizes when I turn the switch but oil pressure stays at zero and the engine won't even attempt to turn over. There is only 3200 miles on the bike. Any ideas?
Uncle Larry (09-04-2017)
More than likely a dead or severely discharged battery.
With the ignition key turned on, what does your volt meter read?
If it's not "10" or higher, even if the engine was to crank over it may not start and if it's below "10" you need to put it on a battery charger (not a battery tender" for a few hours to see if that changes anything.
If your bike is going to sit for more that a couple of days (especially in cooler weather) you need to always hook it up to a battery tender.
JustDave13 (09-04-2017)
