No start - Blinkers flash-no PIN
Old 11-26-2019, 07:55 AM
mskirwin's Avatar
mskirwin
mskirwin is offline
Received 1,534 Likes on 1,157 Posts
I don’t believe the new Fob will work without programming it to the alarm. Of course you can’t program it to the alarm unless you can use the passcode to get the bike turned on.
Step 1
Set the "Run/Off" switch to the "Off" position. Make sure the security lamp is not blinking, and disarmed. The next steps must be completed with less than 10 seconds of pauses in between.
Step 2
Turn the key to "On," "Off," "On," "Off" and "On" again.
Step 3
Push the left turn signal button twice, then let go of it. Wait for one to three flashes from the turn signals and indicator lights for confirmation. The number of flashes will vary, depending on your motorcycle's configuration.
Step 4
Push the right turn signal switch once, then let go if it. The turn signals and indicator lights will blink once.
Step 5
Push the left turn signal switch once, then release it. The turn signals and indicator lights will blink twice more.
Step 6
Press any button on the remote until you see the lights blink twice more. It may take anywhere from 10 to 25 seconds for the lights to blink after completing this step. If you are programming a second remote, repeat this step. The indicator and turn signal lights will flash twice again after pressing the button on the second remote as well.
Turn the key backwards to the "Off" position, then remove it from the bezel. Your alarm's remote is now functional.
good luck.
Old 11-26-2019, 10:40 AM
skinman13's Avatar
skinman13
skinman13 is offline
Originally Posted by Puglia10
the fob worked the day before though, and now isnt working even with a new battery.
ugh.
is there a way to disable (without the PIN) or unplug the security stuff altogether?
I'd rather just lock the bike up then deal with this faulty alarm BS.
good thing it happened in my driveway and not a few states away. Need the bike this weekend for a trip, hope I can figure it out and it wont leave me stranded!
are you sure it is the fob? Have you checked and cleared any trouble codes and reset the system? You could be fighting a reoccurring fail code that is tripping the system. BTDT
Old 11-26-2019, 10:47 AM
fordhd2005's Avatar
fordhd2005
fordhd2005 is offline
Well it's been over 2 years since the OP, hopefully he figured it out.
Old 11-26-2019, 11:34 AM
Puglia10's Avatar
Puglia10
Puglia10 is offline
lol yeah sorry I never updated this. it never really made any sense because it had worked fine for months...but the battery was upside down. cant really explain it, but I flipped it around and it worked again lol.
blap (11-26-2019)
Old 11-26-2019, 05:52 PM
blap's Avatar
blap
blap is offline
Received 3,962 Likes on 1,058 Posts
Good to know, thanks, I've been sitting here patiently for 2 years.
The following 2 users liked this post by blap:
d24112 (11-27-2019), Puglia10 (11-27-2019)
Old 11-05-2021, 03:07 PM
DustyDon64's Avatar
DustyDon64
DustyDon64 is offline
Stage I
Originally Posted by PFWiz
What he said....
what is the pin code?
Old 11-05-2021, 03:34 PM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Received 1,331 Likes on 608 Posts
per Jenny...
Old 11-05-2021, 07:02 PM
Rustyg500's Avatar
Rustyg500
Rustyg500 is offline
I realize the problem has ben resolved but one time I installed a new battery and the FOB was still non-functioning. Turned out the positive side of the new battery had a plastic cover over it so it would not come in contact with the FOB contacts. I removed the piece of plastic to get it to work.
To make matters bad the plastic was transparent and I could not see it. Found it when I went to meter the battery out and it just did not feel like metal when I probed the side of the battery with the piece of plastic on it.
Always something to screw you up.
woodthumb2
06-08-2020 01:58 AM
tmultra
04-05-2017 07:09 AM
sloans4x4
12-23-2016 04:27 PM
T Man
10-21-2016 06:40 AM
rolodog
05-23-2010 05:16 PM
Quick Reply: No start - Blinkers flash-no PIN
